- 24 Dec 2004
- Knowle, Solihull, UK
I've always pressed the button in - ever since being told off by my driving instructor over 6 years ago when I didn't!
the ratchet in the rear hub cassette (admittedly cheaper ones) go all the time without hitting objects , the same sorta ratchet a socket and handrake uses
Button and then pull on the last click
if it doesnt damage it what is the point of the button ??
To release the handbrake?
I teach my pupils to push the button then lift and release when its applied.
Mainly because with all the stop start we can do and using the handbrake PROPERLY then its irritating as hell ratcheting all the time. Also it lets them feel how hard the handbrake is applied.
But you don't tell them it'll break the ratchet if you don't press in the button, right?
How do You Apply the Handbrake?
The button is to release the rachet so you can take the handbreak offJust a question, What is the point of the button being there, if Honda or other makers say your not suppose to use it?![]()
