How on earth did you come to the conclusion that HC2PP was a back workout and comparable to BOR's?![]()
Errr....using my vast experience
- joking aside, just a guess as to how the movement works.....so what does it work out?
- joking aside, just a guess as to how the movement works.....so what does it work out?It's the mother of all shoulder builders![]()
Read up, watch video's and if you're lucky find someone who knows their apples at your gym and ask them to show you and watch your form.Ahhh...thanks! Any good tips at mastering this?
Quick question about burning a bit of fat.
If I eat normally for most days (including gym days), then just go on a lower carb / fat diet on days of doing purely cardio work, will that still work well for burning a bit of fat off?
Or is a cutting diet something that needs to be maintained over a longer than 24 hr period? I guess what I'm asking is whether I can have just 1 fat burning day a week?![]()
What do people think of this routine:
Mon:
Deadlift/SLDL
Bench Press
Pulldowns/Chins
Lunges/L.Press
M.Press
Thurs:
Squats
BOR
Inc. Bench Press
Dips
Ab work
I'm currently doing a standard 3-day split, but time is making this very tedious and I usually end up missing a day... Any help would be appreciated![]()
lol, nice idea but no. Your body doesn't really work off a 24 hour clock. It's more of an average over a longer period that's important.Quick question about burning a bit of fat.
So you want to go from 3 workouts a week to just 2?What do people think of this routine:
Mon:
Deadlift/SLDL
Bench Press
Pulldowns/Chins
Lunges/L.Press
M.Press
Thurs:
Squats
BOR
Inc. Bench Press
Dips
Ab work
and your goal is?Yup, unfortunately.
and your goal is?
What set/rep schemes have you been using?
Bulking up/increasing overall strength. I've just been doing 3x8 (although I'm thinking of doing less reps and possibly an extra set for DLs e.g. 3/4x6).
snip
)?Depends. Week 1 working with something like 70% intensity I can get done pretty quickly and use minimal rest times, typically 60-90 secs. I gradually build upto and over 100% intensity and use negatives, this obviously requires longer rest times and longer workouts.How long do you typically spend on those workouts? And how long do you normally rest between sets?
Scrap the preacher curls in workout B absolutely no problem what so ever, infact it might even be beneficial as the chins are argueably THE best bicep exercise anyway.Also how bad would it be if I sacrificed the preacher curls and rotator cuff exercises (those are like these, right?: http://www.exrx.net/WeightExercises/Subscapularis/DBInternalRotation.html)? Wouldn't I be pretty burnt out at that point?
Yes, massively so imho. It's an awesome exercise that's right up there with Squats and Deadlifts. I'd say it's changed my physique just as much as those two anyway, I love HC2PP!Also, I'm not sure I'll be able to do the HC2PP, purely because there's so little room and the gym gets really packed (again, because it's open at limited times of the day)... I'll certainly try it when possible - would it be detrimental if I didn't include it?
No problem at allAnd how does replacing the CGBP with skull crushers sound (it's just that I like them more)?
