Give it a rest Mark this is getting incredibly tiresome.
i cant remember if i replied to this in a different thread but whats wrong with the current ones?
£80?[TW]Fox;10636854 said:Nothing except for comical levels of brake dust (Apparently German TUV regulations stipulate they must be graphite?).
However I thought since they were near £80, I should see what else is around for the money thats better, or obtain the same performance for less.
out of interest these sensors that need replacing if the light comes on, would most highstreet garages know this i.e. kwiktits and the like?
Kwik Fit won't change your sensors, they won't touch anything on your brakes either without doing a full brake checkup (which is free) , I got mine swapped at a local independent garage (non bmw authorised, just a local place) who charged for half hours cheap labour to replace both sensors. I provided them with the sensors, they did the swap.
You can swap them yourself too with a bit of a fiddle - I needed to raise my car up but the microjack bmw bundle i pants and dug into the ground when the car was raised so for safety reasons I just got it done locally.
Hawk ceramic pads snip
Okay, thank you. What do BMW charge to replace a set off pads?
