Weescott - what voltage that using?
How you comparing this to the 9550?
was not having the unlocked multi on the 9550 a massive disadvantage?
 Also beating a lot of DIce runs.
 Also beating a lot of DIce runs.  And even some LN2 runs!!!!!!1 one !!!1
must be hard using a prommy/vapo on these, look at the expense.
and when faster chips come out you are screwed so about another 200-300 quid to have your unit retuned
/Slaps weescott
The tuning is a once only affair. My units are tuned for 260w load and have universal fittings (chilly1 / Duneik heads). Good for clocking the hotest of CPU's.
I think I caused a brown out in my street. The power went off briefly.
This chip/board is/are a real pain to recover from a failed overclock. I tried to boot at 12x400 and it didn't like it. The only way I could get it to post again was by putting in a Cellery, booting into windows, switch off, put in the Quad, save the defaults quickly (or I have to put the cellery back in) and start clocking again! I had to do this with a Cellery as it didn't like the E2180 either.
