Yes but from your own experience, u have been running it at high volts 24/7 and its broken twice. So thats why I don't think you understand the concept. People in this thread have said they have had no problem at 1.9v for 11months and I believe them. I just broke a stick and I don't think its "unlucky", I just won't run it as high on volts as before. It makes zero difference to me if its running at 1125Mhz or 800Mhz. It will show up in benchmarks, but I don't notice it playing a game.
You are running 850Mhz, 50Mhz above rated speed. Even with 4 dimms I would not be surprised if the RAM could run with +0.0v i.e. 1.8v or closer to 1.85-1.9v due to gigabyte overvolting to start with. I could run at 1000Mhz with 2 ballistix pc6400 dimms with the default voltage. Then I found that to get to 1125Mhz I needed to add +0.2 and later increased to +0.25v to achieve stability.
The point is that with overclocking you use the minimum voltage (usually u do not undervolt) the default voltage, until your overclock becomes unstable. This is a fundamental of overclocking, and without trying to sound patronizing this is something that you are missing and its become very apparent with each subsequent post u make. Read any overclocking guide and u will see I'm not lying.
Whilst I think today I have learnt something from the people of this forum I dont think its my fault. But I'm running the 4GB GeIL/Ballistix combo @ 2.0V 850 4-4-4-12 now and will see if its stable>
 I can really see how Crucial are shooting themselves in the foot selling an overclocking part to the masses. That little email explanation should probably be inside every kit.
I don't think anyone would recommend selling mismatched pairs of memory. You'll be drawing different power from different slots, not a pretty combination.
I would get a refund or sell the other ram and either get 4 matched 1gb sticks, or get 2x 2gb sticks. The 2x 2gb will probably be more stable as well.
Matthew
Depending on the design of the stick of ram, one stick or set of sticks may draw more current than the others.How will I be drawing different power from different slots when they are both at the same voltage?
 Just reading the OP....
I've come home from a long day at work - PC been on for over 24 hours. Turned it off after an update, and turned it back on gain - no POST.
Took the RAM out and tried each module (4 x1gb Ballistix Tracer PC5300) and 1 module by itself works fine, the other 3 by themselves and the system won't POST.
Was just gonna install Crysis again as well.![]()
Will test the 3 modules on another system tomorrow, but it aint looking good for these atm.
Sounded familiar to me, then saw you have a P5K. This happened to me on the P5K Deluxe and Premiums I had. It would be fine then suddenly never boot and no matter what I tried, refuse to. Then the next day it would be absolutely fine. Made no sense. I ended up changing 4x1gb to 2x2gb to get rid of the problems.
Mixing RAM is not good, I tried it with Reapers and OCZ Platinum for 6gb and it worked for a bit then memory errors like mad (all slots and RAM were fine however)
Can you not sell both sets and go for 2x2gb instead?
I could but I really dont want to, my rig seems working fine and I cant see any problems at the moment, I got ram at stock and its fine, its not even been pushed, been playing games etc.. aswell no probs.
