Yep... A friend of mine is running a LG 37" 1080p as a monitor.. its pretty stonking...
You get used to it and nope it's not painful at all.50cm away from a 37" screen sounds really painful.
I have no problems gaming and I don't have to move my head, just my eyes. My response time remains the same.otherwise there's not much point tbh. for gaming I probably wouldnt advice it, as you have to literally move your head from one side of the screen to the other and it just makes a bad response time from what you see to what you do.
Got to say that the "reasonable" is the problem for me. I too have a Samsung 40" 1080p set. Although it is our main TV out of interest I hooked up the PC to it (via HDMI) and it works great. BUT, you do have to be pretty close up for the text to be easily legible, too close for me as you do then have to swivel your head around to see things. I have played games (sitting further away) on it and they look great on it.badbob's pic proves the point that its perfectly viable as long as your a reasonable distance away, its definiately something i want to look into in the future.
Badbob is that on the f86 i take it?
Also! how is the latency in games when compared to any other tft you've used?
Just beware to play HD/Blu ray you will need a GFX Card with HD out.
What's "HD out" VGA can pass 1080p, so can component and DVI.
