Thanks Hex. Mine turned up yesterday so when i get it installed I'll do that.
Any idea what the changes are for the increased stability?
CPU-Z used to read my RAM as Asymetric all the time, now its Symetric.
Remember though that the BIOS Vcore is bugged the actual voltage will be 0.1V less than whatever you set in BIOS.
I have to set 1.525V in BIOS to get 1.425V in Windows.
It would be a good idea to test first before updating...as you may very well find nothing wrong....as mine is running 0603 which don't have the 0.1v bug...and if something went wrong updating your board you could end up with a dead board for nothing.![]()
yup they are nice coolers![]()
am certain you will be trying again tomorrow overclocking is like pringles once you pop you cant stop![]()
