Where have you been getting your info from?
The vast majority of blu-ray disks don't use region coding, the drm is no more than hd-dvd has, was cracked ages ago, and has no effect on you playing legal movies in the player. The interactivity with java is considered better than that of microsofts hdi. And why is not having an ethernet connection for firmware updates madness when 90% of the population wouldn't use it, or even know what it is? It's hardly as if the firmware updates would ever include anything important.
Hmmm, what a pile of misinformation. HD-DVD does not use region coding (although there is the option, it's not used at present), Blu-ray has BD+ and mandatory AACS, whereas HD-DVD has optional AACS (it's possible to release an HD-DVD without copy protection, it is not possible to do the same with Blu-ray), HD-DVD makes managed copy support mandatory for all discs, with blu-ray it's optional (which does effect your legal rights in terms of how you can use the content), BD-J has been added to some players via firmware update (proving that it does include important things) and so on.
There is a reason why studios like blu-ray more than HD-DVD, after all.
So where are you getting your information from?
read what i have wrote you will still have to buy a new player that does exactly the same things as the old player execpt the new player will be able to download firmware thats nice of sony to make you buy a new player just to play the same movies becasue they didnt include a ethernet port on older models think of the money sony will get from exisitng owners having to buy new player thats really fair isnt it
