no agp fix from the look of it.
hmm a hotfix already? i may have shot my mouth of prematurely:
http://support.ati.com/ics/support/default.asp?deptID=894&task=knowledge&questionID=31625
anybody else got an annoying little yellow square in the top left of their screen. it's only on the desktop and other applications will cover it. it's something to do with the CCC as it goes away when you close the systray icon??
edit: i've just updated the drivers on my vista install and i get the same thing again.![]()
Have tried several drivers now, and 7.12 got best performance. (just over 10k with). Tried 7.12 omega drivers and got 9.7k. Haven't 3dmarked the 8.1 drivers yet but they seem to have made no difference at all to crysis performance (which i really thought they might given how hyped the game is).
I've not got the CCC installed however so I don't have that much control over the settings unfortunately.
Matthew
can confirm that 8.1 hotfix works on x1950pro agp on nforce 2 motherboard. happy now since get far less glitches in newer games.
.I don't recommend CCC, it's bulky and takes up entirely too many resources for what it is. I HIGHLY recommend ATI Tray Tools, but it doesn't work with Vista x64...Riva tuner i didn't like very much, and I'm now using ATITOOL which is ok, but no on-screen display when running 3d apps. all of those programs I mentioned are VERY Tweakable and there are great guides to using them on thier respective hompages and tweakguides.com...
(No more constant crashing).
i have to give credit where credit is due. going from driver 7.7 to 8.1 for the x1950pro agp is very good indeed. iv notices a good boost in speed in test drive unlimited on the old athlon xp machine. bioshock runs better now too and crysis is still slow but no more dodgey artifacts popping up.
only complaint i have now against ati is the inability for thier cards to switch to 3d clock speeds when running windowed 3d apps. if they get that sorted then there is no stopping them. (does not effect the x1950pro since it has no 2d/3d clocks, just runs full speed all the time)
they fixed that with their new 3800 series of cards, i dont know about the 2900 because it was the worst card they have ever made but all previous cards cant do it, my x1900xt and my x1800xt couldnt do it, so if you want that fixed buy a 3800 series
are you 100% sure on that? my x1900xt can't go to 3d speeds in windowd apps either.
you deffo 100% sure that they fixed this issue in the 38 series cards?
