Why is it still going to be 32 bit?![]()
yeh im sure they said it will be 64bit only?
It sort of applies to Vista too...
Corporations will not switch from XP to Vista..
It;s faster and more stable than xp as an OS and drivers for game fps is almost there.
I wouldn't be so optimistic, stats are not exactly on Vista's side (I'm on Vista though, don't get me wrong). But hey - there is FatRakoon's benchmark of XP vs Vista in both 32bit and 64bit in the making, so let's just wait for the outcome.![]()
I must be seeing things each day then. Either that or everyone's installed a Vista skin.Corporations will not switch from XP to Vista..
seeing as it's being shipped with pretty much all new computers. Then I expect corporations to switch when they upgrade. But that has always been the case. Corporations are usually behind on the os front.
The fact it's being hsipped with all new systems. Is enough to tall you it's in the same league as 98 and xp. And not grouped with me.
Whilst I worked at a IT corp base units arrived and was installed with a pre-build.
Was using Windows 95 way past XP release date. Only a idiot Network manager would rush out to update the workstations.
a network manager would use Windows 95?
It's the idea of Windows going about kernel the linux way that make everyone go "eeeyyyhhh???". If I understand it correctly MinWin is supposed to be core OS that boots into shell, with networking, basic drivers and some server stuff, like light http, all that off 25Mb worth of files with 40Mb of memory.
Kind of takes you back to times of dos prompt, when you had a choice of booting to win 3.11 or win 95 from the same "base". Or run memmaker and fire up Tie Fighter![]()
Everyone says so, but I actually don't remember that many teething problems with rollout of XP. Few driver issues, Matrox was the biggest problem maker for my XP setup back then IIRC...
We are already over a year after release of Vista, right?.
There's a high probability that it will be. They have shipped a 32-bit variant to testers because there's still plenty of 32-bit machines out there. By the end of this year and especially 2009 the situation will be a lot different.yeh im sure they said it will be 64bit only?
That would just be Microsoft going back to how things used to be. People think that because there was a huge gap (6 years) between Windows XP being launched and Vista being launched, that it will be another 6 years or so before the next launch.
In the good old days Microsoft pretty much launched a new OS every 2 to 3 years, so I would not be surprised at all if Vista's sucessor will be out within a couple of years at the most. Microsoft will not want to repeat the drawn out gestation of Vista, they will, I am sure, cut some fuctionality to get a quicker release this time.
Windows 1.0 launched 11/1985
Windows 2.0 launched 12/1987
Windows 3.0 launched 05/1990
Windows 3.1 launched 04/1992
Windows 3.11 launched 11/1993
Windows 95 launched 08/1995
Windows 98 launched 06/1998
Windows 2000 launched 02/2000
Windows ME launched 09/2000
Windows XP launched 08/2001
Windows Vista launched 01/2007
Possible OS update (will be bigger than a service pack but not a new OS) sometime between Vista and 7
Windows 7 (Major new OS not just a refeshed Vista) new launch date 2nd half 2009 , originally sheduled for early 2010.
MinWin is nothing like "Linux". It's simply an internal project to allow some new developers to get to grips with the Windows kernel.
And no. 40MB of memory doesn't take me back to DOS days. At all.
Did you actually see the same XP release as everyone else? XP was far far far worse.
XP before SP2 was full of security holes and was consistently being exploited.
Then let's not forget all the FUD I would bet even yourself was spreading back then. "Fisher price user interface" "Slow and bloated compared to Windows 2000".
