Just wondering if anyone out there knows the actaul status for the 'capping' that VM do at the mo. I'm on the 20 meg speed and usually get capped about 5ish til 11 ish, yet I've been capped since 1 o'clock today.
 :I do not use p2p or torrents at all, Never have and never will.
After 46 minutes of conversation I have been told that VM are changing the capping times to 1 pm onwards and not 4pm. They have made no mention of this on their website and apparently I am getting capped for the next 3 days solid. They will however give me a portion off my bill if I complain to Customer Service. What the hell is going on with this shower ????
Follow up 1 - apparently I'm getting capped and so is everyone else that shares my UBR for the next 3 days due to maintenance.
Follow up 2 - Just checked speeds and guess what FULL SPEED - VM are at it !!!! Sneeky capping and removal if you complain.
why the heck would this influence your on-line gaming? Gaming uses tiny amounts of bandwidth.
try playing supreme commander when capped on virgin, its bloody terrible!!! unfortunately supcoms multiplayer connection systems based on peer to peer technology and so the data gets a lower priority, 1600ms pings = unplayable.
I don't understand why...should be plenty of bandwidth, unless there's a problem with your connection.
as i said, theres no problem with my connection, COD4, wow, BF2142, under capping they all run perfect, but try to play supreme commander under an NTL cap and i get 1600ms ping times. Im told its to do with how they prioritize the packet data. basically they are assuming supcoms data is just generic P2P stuff and isnt important.
That sounds like Traffic Shaping, which they don't do.
A lot of misconceptions in this thread.
If you're on 20meg you CAN be managed between 4:00pm and 9:00pm. To be capped you have to download 3gb or UPLOAD 1.2gb.
If you hit the limit between 4-9 you will be managed for 5 hours.
You're most likely experiencing contention issues/problems with the network.
I'm sorry but they aren't going to cap you from 1:00pm and why the heck would this influence your on-line gaming? Gaming uses tiny amounts of bandwidth.
This post has nothing to do with online gaming at all. I never mentioned it.
What I said was that I suddenly got capped at 1pm, when the cappong is supposed to be between 4pm and 9pm. Virgin Media agreed I was capped, but then turned it around to say they were working on my UBR and everyone was going to be capped to 5 MEG for 3 days. After I came off the phone, my speed returned to full and I have now just been capped after full speeds since yesterday.
What I'm trying to say is that I belive VM can and will cap outwith their represented times of 4pm to 9pm if they wish, knowing full well that the majority of people who use the net will not notice a difference when browsing the web.
how about playing supreme commander when you are not capped then? do any large transfer after you finish playing so that VM wont kick you down to a slower speed during important times, ie, gaming.
Personaly ive never had a problem with supreme commander online, unless i download something big beforehand that would cause my 4mb to get reduced to 2mb.
Don't get capped then. If you're happily transferring several dozen gigs a day, even for £37pm, you're getting exceptional value for money.i transfere several dozen gig a day. it cant be done over night as the pc is in my bedroom and keeps me awake. the point is i shouldnt have to make any special arrangements, supcom doesnt use that much bandwidth, its just that the type of data it uses recieves a lower priority by virgins servers when your capped as virgin servers see it as P2P file sharing data and choke it.
