There's no mention of sloping water.
In which case every single pool is on a hill. We've all done it.
If you had a sealed container then you could create an uphill pool I suppose
if you tried to swim up hill then all of the water would just fall out. Mind you, you could try drinking it and then excreting it whilst swimming - would that count?
That's not the same question in another way - it's a different question. The problem with a waterfall is that you may not have an absolutely continuous body of water and, even if you did, it would probably only be a relatively thin strip of water and thus you'd make much less contact with it than a large body of water.basmic said:Let's put in another way. Can you swim up a waterfall?
The pool could be on a slope, and the water going downhill could be pumped back to the top.
edit: I know this is totally LOLworthy, but I'm just looking for some answers from everyone.
And this, ladies and gentlemen, is why I love GD![]()
You sir, are a retard.
