i dont know those products, but something tells me they'll be over double my budgetSonic Impact T-Amp and the rest of the cash on some decent bookshelf speakers?
Otherwise, Aego M's are good.
Not as good as a T-Amp and KEF Coda's though, IMO...
That Sonic Impact amp is awesome - I've built a 41hz.com AMP6 kit (which is very similar) and can say I'm more than happy with it...Sonic Impact T-Amp and the rest of the cash on some decent bookshelf speakers?
i dont know those products, but something tells me they'll be over double my budget![]()
I just remembered i have a pair of pretty fantastic speakers at home that just need an amp, but these speakers are pretty big. What are some good value amps at under £100? do they come with volume remotes?
a portable battery powered amp to run 2 massive speakers?Sonic Impact T-Amp
Yep. What impedance are your speakers... It normally says on the back.a portable battery powered amp to run 2 massive speakers?
hey where do i know you from? i think we used to chat on msnYep. What impedance are your speakers... It normally says on the back.
I'm using that (equivalent) amp from a laptop battery pack into 6 ohm speakers, and I can hear it from the other end of a 5 bedroom bungalow, if your worried about volume.
If it was my money, I know what I'd get...
EDIT: 4 ohm speakers will work best with this amp, and 8 ohm is good also. If they are 16 ohms, then it may not be the best choice tho...
Tooks: What amp you getting?![]()
i'd take you up on that but my speakers are miles away from me so cant check,Yep. What impedance are your speakers... It normally says on the back.
mikehun79 said:That Sonic Impact amp is awesome - I've built a 41hz.com AMP6 kit (which is very similar) and can say I'm more than happy with it...
As for speakers... I haven't a clue...
I think I know what's wrong with it (I need to properly isolate the speaker outputs), but it's not until it goes wrong I realise how good it was...
