Surely it would depend on the friction of the wheels against their bearings/hubs? If perfectly frictionless then the conveyor would have no effect, however if there was any friction then the conveyor would serve to slow the plane down.
How completely incorrect in so many ways
my answer/guess is NO..
yes it has the speed, but it doesnt have the movement in the air or whatever for it to start going up..
Dude the plane has to have momentum if it has none it won't leave the ground
The plane gets its lift via the bernoulli effect. This has to do with wing shape and its interaction with air moving rapidly past. If the plane has no motion relative to the wind, there will bo no lift to force the plane up. That plane is going nowhere fast. Kind of.
No offence mate, but he's right. What you said basically makes no sense at all in aeronautical terms. The aircraft WILL be moving, the belt will only make the wheels turn, there is no power transfer from the wheels to the ground.
that makes a little more sense, but your wrong because the aircraft WILL have motion and so lift will be created.
Look up one post
what if theoetically you had a giant fan blowing onto the nose of the plane recreating it running down the runway, would it take off then?
