Mine came yesterday and was delivered by Business Post just before midday after a wait of 3 weeks
2Ghz
2GB
8600M GT
1400x900 panel
120GB 7,000RPM Seagate
9 cell battery
First impressions after getting it out the box were build quality is very nice, brushed metal around the keyboard, no place bends or gives in the case. Keyboard feels very nice and solid, mouse pad is okish not as sensitive as i'd like and abit of a rough feel. Weight is surprisingly light even with the 9 Cell battery. The 9 cell battery does stick out at the bottom, I don't find it a problem and will easierly give at least 1.5 hours more of on battery time. A tiny issue, the left side of the battery is abit loose it could do with another lock on that side, no massive problem but something that underminds the rest of the great build quality of the M1530.
After hitting the power button I was fixed on the LCD display hoping I got a good one. After Vista booted and went into native resolution I was relieved, seeing a pin sharp evenly bright backlit display. I was abit worried about the shiney reflective screen but I really don't find it a problem I went for the 1440x900 after seeing out of interest it is a LG panel.
Vista that comes preloaded runs like a pig. Its terrible that quite a high end laptop is sent out in such a state, nevermind I did expect it though. Within 10mins I was installing XP. Once all the drivers were installed everything ran great and how it should!.. pff bloody vista
If you jump straight in and and start gaming with the M1530 straight out of the box you will be disappointed and worried if the 8600M GT has actually been installed! I'd recommend a total fresh install of XP (or vista if you must
). Then head over to laptopvideo2go.com the drivers their have been tweaked for mobile graphics and they make a big difference.
If you are interested in installing XP some nice people at notebookreview have made a thread that has links to zip files containing XP drivers for all the devices on the M1530.
http://forum.notebookreview.com/showthread.php?t=212981&highlight=169.01
With no overclocking I get a score of 4515 in 3Dmark06.
I had a quick push at overclocking the 8600M GT using rivatuner CPU: 580mhz Ram: 449mhz I get a score of 5329 in 3Dmark06, theres more scope there aswell it seems for oc'ing
. Very impressive to have a laptop that out scores and out performs my desktop which is running a 1.8ghz c2d with x1800XT graphics card.
