Odd, it now takes less vcore to run stable now, yet my temps are more than 10C higher. Would get blue screen and restart at 1.4625 before, needed 1.4875 i think.
Also, Core #1 is borked, fails worker thread #2 everytime, though lasted a bit longer, others passed small FFT's.
Hot core sitting at 39C idle now. Maybe lapping it made it worse, but can't see how thats possible, unless it's now the heatsink.
Mate, check your ACTUAL voltages, not what you set it to?
Sorry just trying to be clear.
Maybe the bios is giving a different "actual" vcore. I'm sorry feel well bad now recommending you change your bios (504 is definately a known dud though)
they look near identical
I can understand that your struggling a bit, but you must stop running around in circles and reading to deep into minute fluctuation in temp and the like.
