It's Vista. Can't remember off the top of my head if I have the N card or the G card. I have heard some people say that Vista has some issues with wireless that will be fixed with SP1.
I also got things to speed up by uninstalling Mcafee as it has some rubbish Proxy on there.
I'm sure if I keep it i'll get to know it's quirks and how to overcome them, but for a supposedly Premium laptop it isn't good out the box![]()
How long does the Outlet take to deliver?
Sounds like I'm going to have to play it by ear on the reformat thing. Althought from the sounds of it a reformat does sound likely.
Anyone got 4gb on an XPS m1530 ? Did you have to install any updates to avoid BSOD's ?
R
mehul
I got 4Gb and it's working fine, no updates needed, OS only sees 3.5Gb but I knew that before![]()
Was that on Vista or XP ?
Thanks
M
4Gb with both, I've got my machine Dual Booted and media direct working![]()
To be honest, the screen is awful, and I think i will be returning it - unless I can convince Dell to replace it
Mehul, I see on notebookreview you've got your screen replaced for a LG.
Mine will most likely be a Samsung when it arrives. I might have to ask you for some advice when it comes to asking Dell to replace mine.
