hmm, tried to get lots of money using the bank method, however my bypasses appear to not work! They stay red and don't got green! Are they of too low level? I have monitor, proxy and firewall bypass all level 2!
Chances are they are too low a level.
If anyone wants to make loads of money with no effort at all, well, its cheating really then:
Go here:
http://www.modlink.net/mods.php?modtype=gateway&pageid=1
Download the gateway at the very top and unzip into your Uplink folder.
So you should have a graphics, data, users and temp folder in the uplink folder.
Load uplink and login.
connect to the uplink server and go to Gateways.
If you scroll down the list of gateways you will see the one you have just installed and it should have a price tag of -11000 or something similar.
Now purchased it. You will get an email and You have just made 11000 credits. You can keep doing this over and over really fast and your bank account will shoot up. delete all the emails.
Fast forward 24 hours until you have received a massive amount of emails telling you that your new gateway has been setup. Log out and back in again.
Now go back into the uplink server and into gateways again. You can now buy the best gateway there. Do so.
Now you can either keep it and work towards the cash in the normal way, or you can again puchase the new downloaded gateway and make 95000 every time you purchase it just as you did above.
Get yourself 2-3 million credits. You can then afford to buy the best gateway, or a better downloaded one. Loads of CPU's and memory as well as all the top of the range software.
It takes the fun out but its good if you've finished the game normally and want a laugh.
Also, not sure if it was a part of the official patches but there was a mod out that added LANs to the game. It is well worth getting as it makes the game a bit deeper and more challenging
