Talk to your boss.
I mean, duh.
read the thread properly
i mean, duh.
Talk to your boss.
I mean, duh.
Your whining about having a Pentium 4? All the machines in out 6th form are P4's - just run some maintenance apps on it. Ashampoo Magical Defrag is beautiful for my vista rig. Seriously I cant believe anyone is complaining about having to use a Pentium 4 lol
Your missing the point, If i was only running office apps then I wouldnt complain but im not. You should see the spec of machines that the company that produce the software recommend.
What software is it? Deliberately killing a working machine is a bit immoral imo. Public schools would kill for that machine I'm sure!![]()
Thanks for all the replies, as per usual this forum doesn't disappoint with its range of replies
I used to have a good computer at my last job, it is the computer I have at my new place of work, that I have a problem with.
As for getting on with the IT department, I'm sure they **** me off behind my back but I am always polite with them. This is the first job I have had where there are problems with IT that take ages to fix (Maybe I've been lucky). Tell me if I am being unreasonable with the following.
Outlook doesn't automatically tell me when emails arrive, I have to go into the inbox and click something, then they appear, either that or I wait half an hour or so for them to come through. Reported it 3 months ago on the It call log thingy, IT reply with "to be fixed within a week", its still not working.
I need to open Autocad dwg files using a freebie viewer, its out of date and needs a newer version putting on. Its now fixed this morning after 3 months, took 5 mins.
Ive brought my own mouse in, its an intellimouse explorer, it has extra buttons which I mapped to do things, i asked for permission and it was ok'd, the y downloaded the drivers for me, they got the wrong ones, mouse drivers still not fixed 3 months on.
These problems are minor but to me that makes the whole situation worse as it really should not be an issue.
I use 3d cad all day its a package called strucad and when you have a big model it can bring a high spec machine to its knees, never mind a generic office machine. The company has a turn over of around £40 million and I'm currently working on a job which is worth £1 million to them and they are dragging there heels in buying me a £600 machine. The problem is that about 30 machines all need replacing its just are slightly better than mine me being a new starter means i'm probably at the back of the queue. It doesnt stop me getting frustrated when you are under pressure to get something done and you have to wait 5-6 minutes to do something which should take 20 seconds.
Just to clarify I probably wont do anything to the machine as other than the IT issues it a good company to work for with regards to money/perks.
We used to use Cads Advance Steel to do that job, plus it plugged into AutoCad easily enough.
Whats the reccomended spec for strucad?
Install Vista.
brilliant. Seriously though, document the amount of work you get done in the week and compare it to your contemporaries on here with better rigs. Businesses don't like to lose money end of, so if a small one time investment will get their well trained monkeys efficient again they'll do it. Take me for example, part time at a well known diy store, and I managed to get one of the workstations upgraded from a ****** dell celeron to a nice new ibm machine
And i only work 9.5 hours a week!
@ mejinks
thanks for the reply, I appreciate there are two sides to every story, ill try an do a report stating facts and figures.
Punch it in the Ovaries...I've started a new job 3 months ago and right from day one I realised my computer was not upto the job. I've gone through the official channels to request a new one and the company ordered 3 but gave them to the longest serving people, with me supposedly having a cast off but 3 weeks later, nothing has happened. I even brought my home machine in to use but after a month sat on the side, they decided I couldn't use it. the IT department here a slow and are a law to themselves.
Is there a way to cripple my machine which is undetectable? should I do this? This machine is driving me mad, I've gone from a good spec machine to a crappy p4 office machine with onboard graphics when i'm a 3d draughtsman... frustrating.... rant over
p.s. excuse typos as I'm on my phone.... to scared to use the works computer!
Are you in a union? I'd consult them if you are is this is obviously making your job very hard to do.
