- 27 Jul 2005
- The Orion Spur
Edit - double post sorry.
is it as picky as the 360, which can only play the most recent incarnations of DivX and XviD?
Short answer yes, my PS3 has issues playing pretty much all of my xvids where as my 360 played them all fine.
Hmmm, I found the 360 to be picky, wouldn't play any of my simpsons DVD rips that were more than a couple of years old...yet you say the PS3 has issues and your 360 is fine...which makes the PS3 even worse. Guess it won't be being a cheap HTPC afterall![]()
Do you copy the Xvids to the PS3 hard drive? If not that may be the problem
it all depends on your codecs mate, I feel the 360 is better for Xvids but the PS3 seems to support my dvix's better.
not long before this turned into a ps3 vs 360 thread
these price drops really make the 360 a bargin, do you rekon we will see a £200 ps3 soon?
that would pricey against ps3 + gta4 for £300
The PS3 never needs to go any lower than the price point of the Xbox 360 elite.
I'll repeat what I said on page 1,
There's only 1 page.
When both blu-ray and hd-dvd are ripped they are converted using a codec into a different file type - from that point onwards they have no connection to the format they were originally printed on, they have the potential to be exactly as compatible with a PS3/xbox360 as each other if the same codec is used..
It all depends whether the PS3 can play the codec that the hd-dvd was converted to. If it is .avi, .mp4, .wmv etc then it'll be fine, however it won't like files like .mkv for example.
Actually it's 'manbags' now, get it right.
This depends on whether you are using the forum default which is 30 posts per page, or you have manually increased this to 40 60 or 80.
But I sense you know this already as you have obviously changed yours, from the default, or would be seeing 2 pages. So I am now wondering what relevance your post had in the first place?
rp2000
Come on! You know I am not as internet savvy as you. What does that symbol mean? It's a variation of a smiley of some sort?
rp2000
