Also if you switch between the core, I've found that the temp goes from 54c for one core and 70c ish for the other core,
Well stone me if you don't learn summat new every day. I've jus selected the drop down menu (the one directly next to the padlock symbol), raised the core up to 850, tested and it passed, then selcted the second option in the same drop down menu and lo and behold, the core dropped down to stock. Switching between the two options deffo shows the clock of both cores individually.
I thought when you overclocked anything using CCC it automatically upped both cores and memory, this shows it does one at a time, and you have to select the second core/memory option. Also if you switch between the core, I've found that the temp goes from 54c for one core and 70c ish for the other core, its as if for desktop useage, only one core is used. Now this might/probably is common knowledge for a lot of ppl here, but I certainly didn't know this.
I am a little reluctant to go back to Cat 8.3 as it produced some nasty flickering during COD4 when flash nades were used.
This switching doesn't hapen on mine, I just get the same clock no matter which I choose from the menu next to the padlock.
I am running Cat 8.2....you on 8.3 ?
Perhaps this might explain it ??
I have managed to manually slide the clocks to Core 870 MHz and Mem 955 MHz and it passes ATI tool for 30 minutes no errors, but my 3D06 score really doesn't improve...maybe I am only upping one core ?
It's not that it's not high enough, it's because you're most probably CPU limited. I'm on cat 8.3s my self, and when I overclock my X2, the "benefits" are small in 3D mark 06 at 1280x1024, but when I play games at my native res of 1920x1200 the gains are more obvious. Overclocking your CPU more will benefit you more too. I don't get any issues with COD4, no flickering or anything, that's with everything on max + 4AA.
In the grand scheme of things with the Crysis benchmark, 3 fps isnt that bad if you're only getting a low frame rate anyway (not saying you are, just hypothetically speaking).
Like i said in the other x2 thread, i am gonna try and do the BIOS flash tonight and see if i get any joy there and see where i can get the clocks to.
One problem i did run into was that at the max overclock for CCC, running a fixed fan speed of 35%, i think the card overheated as it came up no signal so i had to restart.
amd gpu tool needs a updated file to overclock, i think in general you can find links for it around, though i think the article on overclocking the X2 on vr-zone has links to modded config for both amdgputool and rivertuner.
I get that same thing in CSS, though it happened with the 8.2s as well though
If not then i am tempted to go back to the 8.2s as it is very annoying having the whole screen flicker like it is trying to give me an epileptic fit.
