The SFF Case Gallery And Specs Thread
thanks andr3w1984 :)
yeah i like the case a lot. just need to get myself 2 nice monitors now, on
the same mount. and make my set up look minimal
Form Factor: mATX/uATX
Manufacturer: Me
CPU: Q6600
RAM: OCZ Flex 9200
HDD(s): Seagate 7200.11 500GB
GFX: 8800GTX
Speed (if overclocked): 3.2GHz
Temps: 60'c Load (Prime)
Click to see my full Work Log
StevenG
hey StevenG, where did you get your case cut like that please and does it cost much?
thanks
Daz/Tosk
thanks
Daz/Tosk
unfortunately i cant mention the company as its a competitor of OcUK
but the price i can say is £49.99 but this is a rough guide, send them your design and they do a custom price for you.
StevenG
My new build
Manufacturer: Me
CPU: E2140
RAM: Geil 800mhz
HDD(s): Seagate 7200.10 250GB (x2)
GFX: 8800GT
Speed (if overclocked): 1.6GHz
Temps: 30 idle, 40 Load
lol i was told 1 of them would fit in a sg01 but others said it wouldn't :)
looks like i might be buying a new cpu cooler :)
Thx for the pics breezy,
Wouldnt you find it annoying that the memory sticks are under the cooler ? you would have to remove it to get the memory sticks...
and is it one of those coolers where the whole mobo has to come out to remove it ?
EDIT: Just seen, that you can probably leave the cooler on, click the two memory clips on either side and slide the sticks out ? is that what you do ?
thanks for the pics m8
it doesn't look to bad to me. just don't go changing your ram all the time :)
i was told the Silverstone SST-NT06 Lite cooler was just as bad to fit anyway
