- 7 Mar 2005
- Eating PI
Yes I didI take it then you did'nt bother to check my OCDB link
I did'nt say that cpu speed had anything to do with GTL settings.
...If you click the link in my sig you will find the GTL's needed to run at 4.6ghz are completely different from that list...
In a round about way i was saying that the values in your chart simply will not work. When you get your phase unit set up, you will see exactly what i mean. Try using that chart to set GTL values will result in instant BSODS as soon as you run Orthos/Prime. I know because i have a stable system with my values, and imputing yours caused an immediate BSOD in Orhtos.
Well, what can I say... the values in the chart were only given to me by the Head DFI Engineer...
They do exactly the same as the x?? settings on an Asus board except they allow for a little more adjustment... Plus looking at your link again with the exception of your NB GTL's you have them virtually set at the numbers in the 61% chart anyway, so I dont really understand what you're getting at tbh
Plus, why or earth would anyone want or need to run Orthos... total waste of time IMO... It proves nothing, it's not a real world test! It stresses the CPU to basically 100%, which no game & or program ever does & it doesnt take other components into account in the mean time... Stability is just that, I dont bother with prime anymore & have never EVER had an issue with crashes BSOD's or anything of the like... The last time I ran orthos was with my Q6600 & it told me that my CPU wasnt stable @ 3.8Ghz with 1.5vcore... Funny how it ran anything & everything for nearly 9months without a single crash or hiccup...
BALLS to PRIME
. Upon rebooting i check temp in bios and was at 41c.
