- 10 Apr 2006
- North West
Ziphone for PC
Pwnage for Mac
Pwnage for Mac
Not sure if you mean you can't use it if you've used ziphone or if you mean you have to use ziphone first.. but you don't need to use anything other than Pwnage, even on a brand new phone.
1. Take phone out of the box.
2. Put it into recovery mode, connect to iTunes, restore to the latest firmware.
3. Back into recovery mode, quit iTunes, run pwnage and perform the initial pwn.
4. Pick your custom options for your pwnage ipsw.
5. Phone back in recovery, load iTunes, Option click restore, pick the pwnage file.
6. Done.. unlocked, activated, installer.app installed and ready to rock and roll.
No need to run any other apps at all.
So I've downloade Bootneuter off installer, do I need to download anything else?
What are you trying to do? If I were you I would restore it and run pwnage tool which does it all for you. There is a good guide over at mac rumors.
I think you need to add a guide for pwnage tool for your site. If you like I will write a nice simple one for you later today.
To unlock mine i just jailbroke 1.1.3 with ziphone then ran geohots 1.1.2-1.1.3 unlocker program in installer. No messing with the bootloader etc and done in 2mins flat![]()
I'm confused after reading all this
I've just got an iPhone and want to unlock it on my PC. The latest firmware is downloading for it now but after that, which piece of software should I use?
Pwnage
Ziphone
Iliberty+
If I use Pwnage, what functions are missing?
Ziphone messes with the boot loader
Is there any reason why you are staying on an old firmware?
All i did was just jailbreak it nothing else, my original 4.6bl is still untouched
Ive read that 1.1.4 is a better firmware but some apps have issues with it so im gunna stick (for now) with 1.1.3
I used ZiPhone in the end, worked great. Not sure if I'll bother updating the bootloader or firmware (same thing?)
I'm in a flap at the moment trying to sort out my phone so my brain isnt thinking straight - what's new with version 2.0?
Sweet! Even though it's all new, the fact new firmware is coming still excites me
If I was to use a normal o2 sim card in the o2 iPhone, would it work ok or is the iPhone tied to the o2 sim that's in the phone?
