Have I set this RAID 0 array up correctly?
8 Aug 2005
Reading, UK
I got my second Seagate 250Gb drive (single platter) this week and have just setup the two of them in a RAID 0 array, using a 32k stripe. This is my first time of setting up a RAID 0 array and took advice from here and it looks to be running fine.
I was quite surprised when I saw that Windows detects the array as one drive, but twice the size - is this normal? I was expecting it to show a 250Gb drive not a 500Gb one!
Also, is this HDTach large run correct? I guess this means I've set it up fine, and that it was a lot easier to do then I thought it would be :)
raid 1 (mirroring) shows up as one disc with the capacity of half the component discs, raid 0 (striping) shows up as one big disc with the capacity equal to the components.
assuming you wanted the performance boost, and not the protection against one of the discs failing, i think you set it up fine.
Yes I did want the performance boost :) All my data is on a separate drive.
So I essentially have a 500Gb drive that is twice as fast? I guess I didn't read up properly :)
Thanks.
Thanks.
Yes.
Pretty good speeds there. I get 130mb/s with my two WD 2500AAKS drives (don't think they're single platter) on a 16k stripe.
