Project 'sillyteg'
That beather filter looks homosexual :(
Make a ghetto catch tank out of fairy liquid bottle.
I'm probably going to ditch that filter and T a hose into my main breather tank.
Any chance of blagging a passenger ride for your track session (cheeky I know!)
It looks like it's already taken I'm afraid buddy, but I'll let you know for definate nearer the time :)
No worries, I can always go track side and get some shots, what stand you on by the way buddy, i've been meaning to say Hi for about the past 3 years at various Jap shows!
Why would you need to put the crank case breather through a catch tank? Thought it was just the PCP valve that connects the exhaust and intake manifolds that got 'tanked?
Keep the breather filter
Screamer out the bonnet. Do it.
Was watching an old rallying DVD t'other day and you could see the screamer on the first Quattros firing straight down at the ground. Flashes of bright orange flame :D
*n
dooooo it :)
It wouldn't exit there though, it would exit at the front near the Honda badge. Which would look kinda gay.
It would be fairly easy to do aswell :o
Won't it, like, melt my bumper though? I suppose it would be OK with a heat shield. Hmm.............
2mm steel sheet cut into a square with rounded corners and bent (if needed) to fit the contours of the bumper. 2" hole in the middle with a 2" length of 2" steel tube projecting 'into' the car (flush from the outside) and tack welded on from the inside.
Drill 2" hole in bumper, push tube through hole, secure with a pop rivet on each corner of the plate, win.
Screamer goes through the tube (cut flush with the plate/bumper), bumper avoids heat.
Leet MSPAINT skillz0rs:
*n
