Not sure about that manifold Drex!
Still, look forward to seeing it done![]()
Cos its not JDM bling?
Why do they give better spool characteristics?
It would never pass MOT in a million years though.
The energy of the exhaust gases (flow and heat) are contained better.
If you use a tubular manifold, you lose temperature and the longer primaries slow the gases, giving them less energy when they hit the turbo.
*n
its still better to get it straight into the turbo as fast as possible.By how much though, an actual noticable measurable amount?
Just not able to heatwrap it to get around this if it is a problem?
Yes.By how much though, an actual noticable measurable amount?
Er, not really no. This isn't Japanese:
How much was the ebay manifold?
*n
Wow, youve changed your side on that one
Wow, youve changed your side on that one and sounds pretty similar to what i posted a while back
Yes those ramhorns things are total overkill for anything used on a road more than once a month. Minimal volume is far more preferable for anything involving transient engine load, not a 11 second 'pull' at a drag strip.
