- 27 Aug 2003
- West Midlands
Whats the screamer pipe for? Looks like its to stop the turbo boosting too high?
That's what the wastegate is for. The screamer pipe just comes from that wastegate.
Yep, the screamer pipe attaches to the wastegate outlet to dump the exhaust gasses being bled by the wastegate.
Nice IC Ben. Looks a decent size.
Did you get the pipework to suit or did it buy it all custom?
How much did it cost you all in?
Ben.....
You know where that screamer pipe needs to exit...
If you have it pointing out the closest bodypanel, ready to spit flames at the atmosphere I'll do anything. I'll adopt your dog. I'll walk your kids. Anything.
*n
It was a full 'kit' to suit the Integra, only £250 shipped![]()
A right PIA.
should be a lot of fun though when complete
Looking good.
Nice Blox manifold. My GT28RS is just clear of fouling the block with the compressor on the drivers side so I dduno what yours will be like with you're T04E housing. Maybe you could space the manifold from the head with a plate, whats the wastegate clearance like between the cam cover?
That screamer isnt really ideal asside from the packaging. It will end up with exhaust gas being ingested by the compressor aswell as making your engine bay a state, much better to route it rearwards under the car and maybe include a exhaust driven crankcase breather, so on high boost you have that sucking air from the port on the rear of the block (slash cut fitment in the screamer) to stablise the crankcase pressure.
