Broke in 2 - my AMD 6000+ X2 - Fixable? (pics added)
Hello everyone,
I'm a long time lurker here but I suppose this is good as time as any to take the plunge!
I have a rather disturbing true story to tell, while (admittedly not taking my time) removing the heatsink from a motherboard recently, the cpu (an amd 6000+ x2 3ghz) came off with it. While trying to remove the cpu from the heatsink afterwards, I managed to break the pin half of the cpu off the silver coloured part which attaches to the heatsink. The rectange core section is fixed to the silver coloured half, but I think it's supposed to be fixed in onto the half with the pins on? there's black stuff on the core section, I assume which sealed it to the pin half.
I also managed to bend a few pins, but I've straightened them out now.
Is the CPU too far from saving?
Is the core section on the wrong half and would it need removing from the silver coloured half and resealing onto the pin half?
There's a black material shaped groove around the edge of the pin half, I think this helped seal the 2 halves together, but it would need something to help seal it again.
Pushing the 2 halves together doesn't help, because they just become loose again, wouldn't be good on a motherboard, although since the heatsink is held in place I suppose it could be usable - not sure.
What does anyone think? any advice appreciated, oh, you can tell me how clumsy I am too
If anyone is interested, I could put some photos up...
Hello everyone,
