The best thing to do is save your money the PhysX card is in no way worth what you pay for it at all.
[ZiiP]carrot;11636093 said:I get the idea that these physics cards are a bit like marmite...
Think I'll leave of for now then![]()
“Oh, I'm lying am I?”
Yes you are unless you talking about something different then I think you are, you where talking about the physx maps for ut3 are you not?
How is a massive tornado ripping buildings to bits among everything else it did like wind a minor effects that you had to try to notice. How can you call destructible walls, floors, walkways and rooftops minor effects that you had to try to notice?
“Benchmarks?
What have they got to do with anything,”
They prove what the PPU does and doesn’t do. Benchmarks show that in the worse case the minimum FPS drops below 30fps without a PPU and stays above 30fps with the PPU.
I find it very hard to believe your minimum FPS is 60fps unless you’re playing on low settings. Anything that boosts minimum FPS is good.
Ageia: A solution in search of a problem.
Long story short i can currently get one for £15 as it is end of line stock from a local computer store but is it worth the purchase?
Haha that made me laugh - funniest string of words Ive seen...[NVidia] 8+ series GPU's ... all we'll need is a driver ... which isn't to far away apparently.![]()
bledd only Nvidia like them otherwise i don't think they would have brought out Ageia
And that'll be why nvidia, a multi billion pound company, bought them then?
