like so (-:
What is Heroes
Anyway regarding the harddisk, I doubt there will be much difference, I would get the Samsung just because they were (are) known for their silence and with the PS3 I rate Silence > Speed.
Another point though, if you have 40GB of data how are you going to get that on a USB stick?
What is Heroes
So if I swapped hard drives and just saved my "save games" Would I have to deactivate that Hd or is the ID thing for each paid game held on the Ps3 its self??
Does that make sense if not let me know and i'll try and explain it better
Perfect!!! (a bit of arial font and bold won't go amiss though)
On Topic:
I think I am going to get the Samsung as some people have mentioned it may be quieter and apart from that there is no real spec differences between the 2. I will let people know how I get on. At less than £80 it is too much of a bargain to pass up and I have dilly dallied about upgrading the HDD for far too long!!
As always, thanks for all the help in this thread.
rp2000
Sorry for bringing an old thread up. How did your hard drive turn out? I'm interested in upgrading as well.
Where there any problems with this Hard drive? or was it plain sailing?
Sorry for bringing an old thread up. How did your hard drive turn out? I'm interested in upgrading as well, but very concerned about buying a HDD that won't work or isn't particularly good.
Would any SATA HDD work ok? As I don't think I'll need that much space, I'm looking more around the 200-250GB mark.
Perhaps this or this.
Any suggestions.
I'd be interested as well, I'm sure I read somewhere about some concerns over the 320gb 2.5" inch drives but I'll be damned if I can find it now.
No problems at all. Upgraded to the 320gb drive with no issues at all.
Took about 1 hour to backup data to an external USB HDD, 5 mins swap the disks, and 1 hour to restore data.
Tested all games from all accounts and all game saves/data all intact as well.
(mine is the 60gb ps3 for reference).
Post here if you have any specific questions.
rp2000
Just bare in mind when it comes to restoring your back-up to the new hard drive you must use the restore function within the backup options and not the 'restore PS3' option![]()
