You should be fine, it's a more GPU intensive games rather than CPU, see how it goes.
Ok thanks. Really looking forward to playing this now!
have OcUk made a guild btw? I remember seeing a PVE guild, But mainly want to PVP. What server you guys on?
looks like Ill be on Battlescar PvP server with some old CS friends.I got the War Mammothand i was a pre-order
*edit
Clairvoyant - there are 2 codes on the back of my manual, 1 being my product key and the other being my in game item which i assume is my mount.
Got my copy through today, i ordered in time to get a War Rhino, but i can't find a code anywhere for it ??
Went in HMV this morning. £35.99 for the game and it costs over £10 per month to play.
£24.99 online and £8.99 pm to play not sure where you got the over £10 pm from.
Our systems are very similar - you have a better graphics card and I can run on Medium with acceptable results.Hi not sure if this is the right place to ask but here goes.
Was just wondering how peeps are finding the performance atm in conan. I know its early and everything, But im just thinking about getting maybe a new gfx card and just wanna know if its worth it.
My spec is;
Intel Core 2 1.86ghz
8800 GTS 320mb
2gb geil pc6400
xp pro
would i be better off just overclocking the cpu? Or will i get a better increase from my gfx card? Or do i just need to put my burning wallet back in my pocket and be happy?
Thanks
