There was this-Is there any eta or any rough idea on the 901 pricing?
I'm very tempted to get an EEE but I may wait to see how the 901 shapes up![]()
There was this-
http://www.engadget.com/2008/05/16/atom-based-eee-pc-901-on-june-3rd-650-with-bluetooth
That would put it up over £400 I think if the story is correct.
I have an asus 900 eee PC. There is a new BIOS out for it v0501.
The update contains "Updated panel PWM frequency"
Does anyone know what this chages? After hours of searching all I can find is that the new BIOS removes the CPU options (Performance/Power save)
Currently in the BIOS when the option "Performance" is set the CPU runs at 900Mhz and at 630Mhz in "powerssave mode". With the 4400 battery I get only abount 1hr of use in "performace" and about 2hrs45 in "power Save"
The Bios seems to fix a noise issue with the display
"I can also confirm having just upgraded to the new bios that the screen whine has most definitely gone. They've fixed it! Its lovely. It was never that loud, but in a quiet room at night I found it irksome. This is the best reason to upgrade in my eye"
However I am still looking into the posts stating that the option to set the laptop into "Power Saving mode" i.e 630 Mhz has been removed.
Just had a reponce to the support query raised regarding the 4400 battery that we get in the uk with the 900 model. It may be worth you while to drop them a silimar line also if you have a 4400 battery.
My query:
I would like to log my dissatisfaction with the specification of the battery which the UK has received over other global territories. The unit I have only has a 4400Mha battery where as other territories are receiving 5800Mha.
With the increase in specification over the 701 the product does need the higher capacity battery. I cannot understand why the 900 has a lower specification battery over the 701 and the 900 model in other territories.
At the moment I feel that the unit is not acceptable, as in order to get any type of battery life out of the lower capacity battery I have to run the unit in all sorts of power saving modes which defeats the object of having a a laptop of that specification.
I have also read that HK users who were provided with ther 4400mha batteries are reciving replacement 5800 batteries, is this going to happen in the UK?
Response from Asus:
Dear customer,
Currently Asus UK is reviewing the battery issue.
Kind regards,
Asus Support Team
Any idea how much an 8.9 inch msi wind will cost?
Hey,
I just bought a 701 2GB on ebay.
Just wondering if theres any mod to put more space in? (Apart from putting an SD memory card in obviously.)
