No Fox, it most certainly isn't. Getting good mpg from normaly aspirated engines isn't too difficult.
I found the Mini CS the worst in relation to engine size vs MPG. Prob worse as the supercharger is constantly spinning moreso than a turbo?
fox is just jealous because he bought a beemer rather than a Skoda
No it isn't. Don't be daft. Even at motorway cruising speed the turbo is spooled up.
[TW]Fox;11902377 said:You should try it, beats washing sick out of the back of a diesel Skoda.
But there isn't as much load on the engine so I'd expect 40MPG is attainable at 70mph
On a side note the turbo is only spooled when accelerating, during motorway cruising conditions unless you put your foot down the turbo isn't spooled / producing boost.
Easily. The LCR runs a 9:1 compression ratio too so its hardly low (relatively).
Quite. Else there seems little point in using a small turbocharged 4pot for efficiency really
Easily huh?
Want a go?
