GET IN THERE 42.5 mpg in a LCR
A 1992 Rover 220 Turbo is quoted at 45.6mpg for Extra Urban. At constant speeds a turbo is much economical than a NA engine
I can't wait til someone starts a "GET IN THERE *insert random amount* mpg in a Mondeo/BMW" thread and its full of praise :)
On a side note the turbo is only spooled when accelerating, during motorway cruising conditions unless you put your foot down the turbo isn't spooled / producing boost.
Quite. Else there seems little point in using a small turbocharged 4pot for efficiency really :confused:
Easily huh?
Want a go?
Eh? Want a go at what exactly? Driving an LCR to achieve the best possible MPG - no thanks it might sludge up on me. Dont tell me you have got upset at another one of my posts.
Downsizing is the short-term future for gasoline engines. The 1.8T is a good example of an early effort, relatively high compression with a turbo added for performance when needed and efficiency via reduction of pumping losses under part throttle conditions.
