- 27 Jul 2005
- The Orion Spur
<crawls out of bed>
WOW, glad I didn't buy a GTX280 on release day !!
Hmmm at 1680x1050 it looks like its worth spending the extra and getting a 280
At 1680x1050 the 4870 beats but mostly matches the 280 so i dont know how on earth you work out the 280 is worth the pemuim over the 4870.![]()
Well going by the earlier review, it was a good 10-15% behind on most of the benchmarks, so thats "how on earth" I worked it out
That would be 10-15% behind on performance and 50% on price... I still can't quite work out how it's worth the money.
For Steedie's sake the 1GB 4870 better not make a big difference & be cheaper with itSteedie,
Unless i'm blind or going blind (hmm maybe)
That bench etc shows 1gig gtx280 vs 4870 512
Don't you think 1/2 the amount of memory may have an influence ?
Or maybe i'm reading memory doesn't really mean anything ?
Ohh well c'mon ATI he he
Ciao
Def
No logic behind it at all?
I want the best performing card without having to go SLi/Crossfire, I can afford it, what's the problem?
So in short, this card will be better than my 8800? Will Crysis be playable at 1680 x 1050 with 2x aa and 4 x af?
I don't want to upgrade until there is an affordable card which can play Crysis without chugging along or showing no visable improvement on my existing card.
