Well maybe not. One of the improvements alleged is the shared frame buffer, so a 1Gb card means 2 GPU's have access to the same memory pool of 1Gb![]()
Wouldn't that halve the available bandwidth?
my first play with dual cards!
I think they have to underclock both GPU and MEM speeds when they build am X2 style card, probably something to do with everything being squashed together and getting extra hot!
Two separate cards run a bit cooler and most likely have faster GPU/Mem speeds.
That's fine if you have a x38/48 board otherwise![]()
Which brand did you order?
...I don't want to upgrade motherboard shortly before a socket change.
Sorry for an OT post, but what is the upcoming socket change?
Jeez man the socket change is next year!!!
Then it will be a few extra months before it works properly!![]()
Intel's new Nehalem CPUs are going to be using a different socket, I think they're using socket 1366, and are due out early 2009.![]()
