and if i wanted to change the fan speed, i would just use that bios editor?... how safe/dodgy is using a peice of software like that?..
It's not that dodgy..although it's always a good idea to have a spare card around to reflash it just in case something goes wrong. And until we have software driver control, the bios is the only way to control the fan (unless you have an asus card).
Hey gurusan,
So if you clock a 4850 to 750/1100 how far off the benchmarks of a stock 4870 would you be and would you need to pencil mod to get above 720 on core?
I don't think I would be very far off at all. However I did try 750mhz with just the bios voltage adjustment and it crashed...I did not try below that so it may be stable at 740mhz or so...
So yes you would need a small voltage bump by doing the pencil mod or something....but then you might as well just go to 1.3ish because then you are good for over 800mhz
Until I see concrete proof that GDDR5 does anything significant I believe that the 4850 is far better bang/buck than the 4870. The 4870 performs roughly 25% faster than the 4850, while having a 20% faster clock rate. So that means the gDDR5 is giving a measly 5% increase in performance for what, another 80 pounds?
