- 3 Nov 2004
- UK
I'm afraid it dosen't. The +12Volt rail can only provide up to 425 watts of power which is around 36 amps. You do not simply add all of the +12Volt rails up to come to the conclusion of how many amps a power supply can provide because you cannot load up all 4 rails to their maximum simultaneously.![]()
That's true, although the actual 12v combined wattage might be a bit more than 425W (580-155) depending on the 3.3v & 5V rail loads. From system estimates (based on mains values after efficiency losses) seen in reviews that would seem to be enough or possibly borderline depending the rest of the system. It may be the case that the psu individual rails are exceeding the OCP limits. I'd try crossloading the rails before giving up on it.
