Radeon HD4850 1920x1200 Benches Please!
That's ok, as said in the opening post it's a more relaxed thread! :)
However can you run the same settings as us please to compare! :cool:
Crysis 1920x1200 High Quality 8x AA
3DMark2006 1920x1200 8XAA 16/AF pls!
Sorry, That will be a while, those figures were from My notes the System is all in pieces ATM and Life is a bit hectic at the moment :D
p.s Don't forget the copy of Your bios You were sending Me Wayne..cheers
Updating as I have disabled the Aero interface in Vista and also disabled all the CPU thermal thottling techs which as you can see has made a big difference now!
my.php
well i am getting a 24" montior in a week, if anyone can just do an intensive cod4 session online, or in game, and do the 4xaa 16xaf with max settings at 1920 please?
then try forcing 8xAA via the CCC and see hwo much difference it makes?
itll convince me to get this card over the 4870 :)
Hi m8, only got the COD4 demo installed atm but will have to look into buying myself a copy as the demo is ace!. I wondered does the full version come with different graphic settings because this demo appears to be limited to 4x AA ;)
The demo plays nicely anyway, been through it a few times trying out all the different guns laying around!, using fraps the frame rate varies between 55 fps to 170fps.
On a side note I have just started clocking this card a little, I let CCC find the max but it started Texture Flashing in DMC and Crysis so I kept nudging the memory down a bit until it ran clean. This is still using the stock cooler and with no mods so nothing special . . . but a start none the less! :D
ok,whats the best score on the DMC benchmark?
Does that matter?
Just post the results you have with your setup. This is supposed to be an information gathering thread, not some pathological e-penis pumping competition.
I'm still not convinced on your crysis score. Something is amiss. Technology does not suddly offer massive improvements for no reason - it simply is what it is. You should check that everything is being applied properly in-game. Check LOD bias settings etc in your control panel quality options.
On a different note, thanks to everyone contributing. Always nice to see a range of different user benchmarks. The 4850 looks like a great card, even for high-res gaming.
Looks like I cant do any benches and compare with people, my monitor only runs at 1680x1050 max :(
Hey Willz, nice one you got a new shiney! :)
May I suggest you start a new thread called: Radeon HD4870 1680 x 1050 Benches Please!
A Radeon HD4870 running games at 1680x1050 is gonna be SCREAMING!!!!!! :eek:
I know this means there will be a few different threads but I reckon it will make it tons easier for peeps to compare kit instead of trawling through one-size-fits-all-thread.
Hey MiNxYyY, does your trust email work? if so can u check it pls! :)
I am trying to get a few of your screenies but you not answering! :(
Some of these benchmarks look very unreal to me.
I can only get 48 FPS on the same test with a 4870 @ 1024x768 and even that is without AA applied as it drops with that enabled so struggling to see how some can get a lot more than me when the test is GPU bound.
0x AA = 32.295
2x AA = 22.615
4x AA = 20.135
8x AA = 22.785
Ok you guys were right, there does seem to be a bug of some kind in the above tests? Not sure if this is the benchmark tool, the game or the ATI driver?
Pretty much done with Crysis now but will come back to it one more time when I worked out the final overclocked on the HD4850 and add a few more MHz to the CPU speed. :)
P.S: if anyone knows some good game demos that can be benched pls post a link here, ta!
