Man of Honour
- 5 Jun 2003
- Falling...
Errr, how exactly do they do 'nothing'? They do exactly what they are supposed to, protect your hands from the bar grip. Wearing gloves or not makes zero difference, lets not turn this into a 'macho' thing, you shouldnt be putting someone off wearing gloves if thats what they want to do, just because you look down on them.
Personally i use them because of my job, because i cant really afford to have hands that feel like sandpaper when im shaking the man of a man worth millions, its just not done.
And if your gloves are rucking up and hurting when your doing deadlifts then suggest trying another set of gloves.
It's nothing to do with it being a macho thing :/
I shake the hands of people worth millions too, they don't give two hoots if my hands are calloused. Besides they can tell I'm a man that likes to look after themselves, in fact it often sparks conversations (rugby being the main subject).
You get a much better feel the for the lift without gloves, use chalk, chalk is fine - your grip strength will improve. Your technique will improve because you can actually feel yourself lifting the weight. If gloves makes such a huge difference then you're lifting weights that are too heavy for you anyway.
Then again I did a lot of manual labour in my younger days and was active kid so my hands have become rather tough as a result. The snobbery of tans and callouses I think have long gone, certainly in the circles I mix with.
I really wouldn't recommend doing deadlifts with a mixed grip. It causes imbalance in your form, which you really can't afford when going heavy.
I disagree. A lot of professional powerlifters recommend doing them that way as you get better control of the bar. Secondly as PK said you just alternate them either between sets or reps - certainly when you start lifting heavy.
