http://www.overclockers.co.uk/showp...=Arctic Cooling Accelero S1 Rev. 2 VGA Cooler
Put one of these on my 4870 today. Bit fiddly to do but well worth it and you only need to add either a 92/120mm fan with cable ties (I used a Xilence 120mm which is silent: http://www.overclockers.co.uk/showproduct.php?prodid=FG-000-XI). CFM is 44 not 68 as the webpage states but that is still good enough.
All the ram heatsinks are included however 1 is partially obstructed by the heatpipes on the cooler but you can twist it around then when you tighten the screws up it kind of holds it over 95% of the surface area (all of the other 7 heatsinks fit perfectly). The strip heatsink for the VRMs you can only use 1 screw to attach it and then have to use something else on the other end as the hole is not aligned (I choose a high tech material-Blutack!!).
Stock Temps before:
Idle 79-82C (depending on air temps)
Load 86-92C (depending on air temps)
Stock fan speed was only around 24-26% on load and 14-19% idle (depending on air temps). This was very noticeable to me as my other 4 case fans are silent and the 4870 gets quite loud under gaming unless you have your volume up really loud you may hear it. When I noticed it started to get bothered so had to do something about it plus lower temps are always good.
Temps with Accelero:
Idle 42-48C (depending on air temps)
Load 52-61C (depending on air temps)
Massive gains and never goes above 61C no matter what plus it is silent.
I will overclock it now as there is obviously a lot of headroom (I know the GDDR5 can hit 4400) and it is still running much cooler plus case temps have dropped by 4-6C so its all good.
Reckon it can get close to the GTX280 @ stock speeds but obviously the extra £££ spent means that it is only £30-40 cheaper overall although I suppose with the lower power useage its much cheaper to run!!
Stock Temps before:
so i cant really say
