The problem is that many do not have the comparison of seeing a movie at 50/60 fps & just take it as is because that all they have ever been given & don't know any better.
I used to be happy with 24-30fps & that's because i had never seen 60fps before hand
Seeing is believing.
I'll have a look at a clip off here and I might be a changed man.
________________________________________________
Well in theory the eye can be even quicker in detection.
A very fast laser flash the eye can see faster than the figher pilot scenario - however that would be quicker cos it picks up the light cells that are sensitive on the eye.
Don't forget we're talking about movement here - which is slightly different . The links that peeps have given are a good point to read if you want.
Smoothness of movement also depends on the distance between each frame.
If you're playing something slow and the movements are close together it won't be so obvious.
A fast game - eg car games - you would need faster frames to have the frame difference closer together.
I think the problem is - is that even though most of us can live with 24fps for movies - with the blurring ; with a computer game even though it can have blur ' crysis ; grid' because you are directly interacting with the scenery you would want an instant response to your actions and that is where 24fps wouldn't be good enough - and certainly with grid you would get even more lag etc. I did notice a bit of lag even with slower crysis once I was moving around quick - however once I moved slower on crysis it was ok.
Myself personally I can tell a difference on the game bioshock . at 60fps it's smoother than lower frames because of no transition 'blur' between the frames but as above if it did have motion blur if it was too low once I moved quick I would notice lag I'm sure.
And I'm sure Grid would need a healthy framerate as it moves so fast - interaction etc. as been mentioned before regarding this fps discussion.
Well that's my 2p worth.
I'd like to have a taste for those 60 and 120fps clips but computer says I don't have the required codec
