Post your dock
Commissario
16 Oct 2002
In the radio shack
Turn your Mac on, and in the native state before you open anything, take a shot of your dock and post it.
I want to see custom and pretty icons and things!
Safari was in a big set called Ekisho and the Finder was by LordKokkei but I can't remember where I downloaded it from.
Feek, I have to ask, thats a pretty purdy dock there, I think I saw some reference to changing it. Is that an old style dock?
Bod!
It's just the normal Leopard dock but with 3d turned off.
In a terminal type
Code:
defaults write com.apple.dock no-glass -boolean YES
And then restart your dock
Code:
killall Dock
And it'll change.
Mine only shows the Finder icon and any open apps. Spotlight / Quicksilver / Launchbar is a more efficient way to launch apps than fishing around with the mouse :)
agreed, but if mouse is in hand whilst browsing and you want to find some piccys or play music from itunes then its quicker to keep hand on mouse and click once than remove hand, type, replace hand. :)
oo and
I know you said post with no apps open, but it doesn't matter because all of these apps are on my dock even if they were closed :p
The stacks I've got in my bar though, How can I change the icons their displayed as?
Bod!
In a terminal type
Code:
Code:
killall Dock
And it'll change.
Aha! Feek!
Cheers for that my good man. All done. I've spotted this browsing through various mac sites, but never had the guts to try it (being a mac noob n all).
Looks much better now :D
