In BIOS I think I am around 1.42 V, idle 1.400V, load 1.416V solid.
I have my PL at 10, orthos has been going 1 hour 45mins so far at 4.2Ghz.
My ram is PC8500 5-5-5-15 G.Skill 2x2GB, its currently at 467*2, 5-5-5-15.
All in all this mobo is a lot better than my P45 Platinum was, just the larger user base for this mobo alone makes it better.
When and if orthos fails I'll go take some screenshots of my bios settings and post em.
Godsbrother, Auto is bad in case you did not know it already, think its been stated, everything gets overvolted.
Why lock it close to the recommended setting and not to the actual recommended setting?
Does it give an speed boost - that extra 1%?
hmm I can get 4ghz with most settings set to auto using 500 x 8 @ 1.3 with a E8500 E0 if I set the voltages as you have suggested one of them (dunno which) stops me booting (blank screen) I'm using OCZ PC8500 platinum any suggestions?
JumperFree Configuration Settings
AI Overclock tuner: Manual
CPU Ratio Setting: 8
FSB Strap to North Bridge: AUTO
FSB Frequency: 500
PCI-E Frequency: 101
DRAM Frequency: 1002
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: Manual
1st Information :
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 15
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time: 55
Write Recovery Time: AUTO
Read to Precharge Time: AUTO
2nd Information :
READ to WRITE Delay (S/D): AUTO
Write to Read Delay (S): AUTO
WRITE to READ Delay (D): AUTO
READ to READ Delay (S): AUTO
READ to READ Delay (D): AUTO
WRITE to WRITE Delay (S): AUTO
WRITE to WRITE Delay (D): AUTO
3rd Information :
WRITE to PRE Delay: AUTO
READ to PRE Delay: AUTO
PRE to PRE Delay: AUTO
ALL PRE to ACT Delay: AUTO
ALL PRE to REF Delay: AUTO
DRAM Static Read Control: Disabled
DRAM Read Training: AUTO
MEM. OC Charger: AUTO
AI Clock Twister: Moderate
AI Transaction Booster: Manual
Common Performance Level [10]
Pull-In of CHA PH1: DISABLED
Pull-In of CHA PH2: DISABLED
Pull-In of CHA PH3: DISABLED
Pull-In of CHA PH4: DISABLED
Pull-In of CHB PH1: DISABLED
Pull-In of CHB PH2: DISABLED
Pull-In of CHB PH3: DISABLED
Pull-In of CHB PH4: DISABLED
CPU Voltage: 1.275
CPU GTL Voltage Reference (0/2): AUTO
CPU GTL Voltage Reference (1/3): AUTO
CPU PLL Voltage: 1.52
FSB Termination Voltage: 1.26
DRAM Voltage: 1.92
NB Voltage: 1.26
NB GTL Reference: AUTO
SBridge Voltage: AUTO
PCIE SATA Voltage: AUTO
Load Line Calibration: Disabled
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
CPU Clock Skew : AUTO
NB Clock Skew : AUTO
Advance CPU Settings
CPU VID: Default
C1E Suppport: Disabled
Max CPUID Value Limit: Disabled
Intel® Virtualization Tech: Disabled
Vanderpool Technology: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
Img speaks for itself![]()
whats the best way to test my ram for how high it will go
it is OCZ pc2-6400 gold edition 4gb kit 2x2gb. cas5 5,5,5,18
i feel its this thats holding me back going higher than 9 x 425 fsb
Thanks
Bowza
I wish there was a proper over clocking guide explaining each feature.
2) One of the critical factors to higher FSBs on these boards is the Performance Level setting. A general rule of thumb I use is:
400-450FSB = PL7
450-485FSB = PL8
485-500FSB = PL9
500-550 = PL10
Settings will vary according to memory frequency and the actual brand and model of memory you have. Just remember to use a conservative PL setting if you are having problems hitting higher FSBs.
Weird thing is, when PL is set to 9 the pc wont boot at all, have to set it to 10 to get it to boot, any idea what the PL setting is doing to make it boot? I need to get the PL down.
the lowest i can get my rams PL is 10, i lock up at 9
P.S: My personal finding regarding the PCI-E frequency have led me to conclude its just fine running at 100MHz, I think this 101MHz is some legacy tweak from days gone by and is no longer required . . .
The one thing you may notice I pick up on is people posting up second hand/untested info to new users as gospel kinda!I do it "to be on the safe side". Old habits die hard.![]()
If the person who has posted the info has tested and confirmed it then thats brilliant but if it's something you just do because some bloke at the pub told you then I worry a little!
And yeah I remember the whole 101MHz PCI-E frequency from many years ago as it seemed that some older chipsets didn't lock the PCI-E frequency unless you set 101MHz or higher . . .
Anyway I will be watching this thread with interest as the P5Q-E was the board I originally intended to buy but opted for the deluxe because of it's 16-Phase PWM setup whereas the E has 'just' 8-Phase!
8-Phase vs 16-Phase? Does it make a difference? This thread should show us the answer to this question . . .
"Can a P5Q-E overclock as well as a P5Q-Deluxe?"
over to you guys!![]()
when u guys say slacken off the memory timings what do you mean
