Right,
the gaps on the front of my car are.....horrendous. It's the only thing that really annoys me about it to be fair.
The bumper is the worst thing, it must be 5mm lower than it should be, I'll be taking this off soon to see if I can reposition it. What is more annoying is the gap between the passenger wing and the bonnet, its big at the top, small at the bottom.
Does anyone know if there is much I can do about this? I hate it so much because it's so blatantly obvious if your looking at the front of the car from pretty much any angle.
Is it a case of loosing the wing and tightening it back up in a different position? or does it take a lot more than that?
Many Thanks,
Jake
Many Thanks,
Jake
MKI
