to much hype would give it a bronze. if judging buy graphics yes it stunning but game play is bad
What was wrong with the Gameplay? I thought it was an excellent single player game and I thoroughly enjoyed playing it.
WRONGAs if you would be able to get away with that easy just by getting it through steam
and be charged a lot per minute. plus you only get one more.Ok so I'm wrong but that doesn't mean it's 5 installs and that's it. I'll just call EA while everyone else cries like babies and throw their toys out the pram in their misguided outrage.
Really? Oh thats good. I was told it was a high rate number.It's actually the same as the national BT rate. If you want to complain about dubious practices by EA (of which there are plenty), this ain't it.
i see no comments here about install problems so this seems isolated to myself.
twice i choose install on F: (my games partition) and the installer said not enough room on C:, made room on C: started the installer again and once again choose F: and the game installed on C:
anyone else had this?
[TW]Fox;12553101 said:What was wrong with the Gameplay? I thought it was an excellent single player game and I thoroughly enjoyed playing it.
i have my games partition on F: as well.mine installed there fine. i did have problems with the disk not spinning up during setup though. i had to copy the disk to an iso and then mount it, then it installed fine
though I do wish it had some more indoor levels
I had an issue similar to that with the disc not spinning up, at the beginning of the install it must have sat there for 10minutes before i took the DVD out and put it back in, then away it went.
Weird.
Unlimited installs unless there are any significant hardware changes.Thats not how it works, you can activate 5 pc's with it, and on those 5 PC's - UNLIMITED installs.
It's capped to 5 PC's, not 5 installs.
And how is the gameplay bad? The actual mechanics of shooting are the best of any FPS imo.
The reverse argument most held against Far Cry, brilliant. Although i agree entirely.
