Caporegime
- 9 Mar 2006
- Surrey
Yeah but you don't need to fiddle with any of them to play games. (aside from player accounts which a fool could work out)
Have you actually read the rest of the thread?
Why don't you tell them if they change the language they can't use it....
Sounds like they are too young to be using an xbox to be honest!
The pads turn on just the same if you hold the start button instead. They'll also turn the console on if everything is off, just like using the dashboard button. Give it a try!
That really annoys me, as in the leaflet you get with the controllers it clearly states that holding start should turn on ONLY the pad, which would be awesome if it actually did >.<
How are they more complex? You put the game in and play it.
Think of the countless uses the button on the controller gives, like when low on battery it gives you the amazing light show that lowers its battery life even more
