- 2 Feb 2007
- Belfast
My v1000z just got delivered![]()
YAY
Hate to say it...but it's just a back to front V1000 isn't it?
Well...along the lines anyway, other than the board is inverted.
Basically yea, with a few extra handy features![]()
1) Side window comes with the case
2) Extended powersupply bracket (creates more room)
3) Extra 200mm fan for cooling pci-e cards etc
4) newer HD racks for better ease of use
And the fact that its ATX instead of rATX
thats basically he main things anyway
Are the hdd racks removable then?
I thought the PCI-cooling fan was 140mm. A BS-04.
Any chance of the pa120.3 fitting internally on the roof or is space too tight? Im really considdering one of these for my first watercooling build but I've decided I want it all internal.
It was more clearance against the motherboard/components I was concerned about, Im not saying mounting it on top is worse, just after a bit of input from someone that owns one.
I wont be using the 200mm fan btw, just not nessesary when il be watercooling this rig in a few weeks![]()
Does it blow or suck? Would you consider selling it?
I'm pretty sure it's the 140mm as I stated above, Lian Li don't do a 200mm PCI cooler.
By default it's set to exhaust, but it can be easily flipped over if you prefer.
