your welcome mate ..Thanks to all who helped here, especially GarethAll back up and running!
Mixed results, started off at 730/1130 - Tearing, temps @63° which is good.
720/1100 - Excellent, temps @ 62° but only yields in between an extra 2 and 4 fps compared with original bios @ 700/1080.
As ghost mentioned, some cards can`t get up to 750/1150 it seems.
In perspective though, out the box 3dmark 06 scored 12132, with 700/1080 12636 and with modded bios@720/1100 12871.
same here but my mod bios works fine with it.Vista 64 with a Sapphire 4850.
8.9 drivers? they should work. point it to C:\ATI\SUPPORT\8-9_vista64_dd_ccc_wdm_enu_68906\Packages\Drivers\Display\LH6A_INF\
if u wanna flash to your old bios just use your backup bios or go to http://www.mvktech.net/component/option,com_remository/Itemid,26/ or techpowerup and download asus bios.
Dave, just saw you have the same issue I had, try using atiflash to flash in DOS...![]()
Thanks again GarethI now have a bootable 4Gb pen drive which I will keep for nothing else. I`ll just keep adding any applicable apps (ASUS Ezflash for mobo for example) and updated bios
some pen drives are not bootableHow did you make pen drive bootable?
I tried to make a flash drive bootable for the purpose of flashing in DOS, but it failed miserable, I used the guide from Here..."Making a bootable USB stick"...
There's a really useful HP tool you can use, whats your email address, I'll send it you.
It was the HP tool that I was using, "SP27213", however, using the link supplied by Gareth, it would seem there is a more recent version, "SP27608", so the problem may have been that I was using an old version of the HP utility, or simply that it is one that cannot be made bootable, but I have a few others (flash drives) I can try, if the need arises again....
Thanks for the link Gareth...![]()
Have you got the DOS files too? You need them to get it to work.
